pritcham's avatar
pritcham
Follower
Sep 29, 2021
RAIDAR Unable to locate my READYNAS DUO
I am unable to connect via RAIDAR to my ReadyNAS device but I am able to save and retreive files stored on the device.   Life support and background task lights are blinking and I have supplied a p...
  • Sandshark's avatar
    Sep 29, 2021
    if you know the IP address of the NAS, you don't need RAIDar.  Just browse to https://<ip of your NAS>/admin.
    If that's what's failing, check your browser security settings.  If set too high, it won't give you the option of accepting the NAS's self-signed certificate, it'll just fail to connect.  There may be some browsers that no longer have that option (I don't keep track), in which case you need to try another.
ProSupport for Business
