Jaap74
Jan 13, 2012Aspirant
Songs not playing in correct order on Twonky
Hi, Just installed Twonky on the ReadyNAS Duo with some help from this kind board however the songs in albums don't play in the correct order. I had the same issue when I had Twonky on my PC so I d...
mdgm-ntgr
Jan 13, 2012NETGEAR Employee Retired
Have you had a look in the "twonkymedia" share? If you connect to the NAS using CIFS (also known as samba) i.e. via Windows Explorer as "admin", you should see a "c" share. Inside that will be a twonkymedia folder. I think there might be one or two other folders in the "c" share to look at as well.
