theonlyjustin
Aug 02, 2015Initiate
WINDOWS 10 - ReadyNAS Remote not connecting
Initialization Failed.
For more information, please visit:
http://readynas.com/remote
Error Code: -3
Since updat...
MurrayMartin
Aug 07, 2015Guide
Leaving all of us who have depended on our systems with "a too bad message " is not an acceptable way to treat your customer base
this can only cause us to leave for another supplier, after having used your products fr many years
do not allow this to happen
fix the problem
JennC
Aug 07, 2015NETGEAR Employee Retired
Hello,
Engineering team have already confirmed that there will be a plan on an update for the ReadyNAS Remote to work with Win10. There is no ETA yet but they are currently working on it.
- MurrayMartinAug 07, 2015Guide
Thanks for the positive news re W10 fix being planned for rnremote (legacy)
i look forward ward to testing the beta version as soon as it is available
please advise
thanks
murray
- kabellAug 08, 2015Aspirant
Thanks a lot. I'll look forward to a win 10 compatible version of ReadyNasRemote
This is really another speach, than the support writes to us. I think you should tell them about this to stop the great amount of frustration by your customers who gets only an answer: EOL.
