Euschrj's avatar
Euschrj
Ready NAS NV+ 4250 v3 drive migration
I wanted to ask the community if anyone has successfully moved clean raid 5 disks from a legacy NV + Sparc version 4.x to the latest NAS 412 ver 6.x?
My old NAS died and presently has my data hostage. Seems I can pay 200 for a piece of software to try to recover my data but initial review appears it will not retrieve the tree or file names. Or I can pay NETGEAR 180 with no promises.
Just checking my options.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    So your backup is not up to date? It's important to backup important data regularly and not just store it on the one device, no matter what device that is. Like all PCs a NAS will eventually fail.
    Were you using X-RAID? Or if you were using Flex-RAID which RAID level(s) were you using?
    The process for moving disks across from a Sparc ReadyNAS to an OS6 ReadyNAS is described in ReadyNAS: Migrating disks from RAIDiator 4.1 or RAIDiator 5.3 to ReadyNAS OS 6
    This would result in purchasing a data recovery contract for support to attempt to recover your data. We don't know what state your disks, array, volume etc. are in without looking at it.
    Another option is to use an ordinary x86 machine running Linux. There is a straightforward process to attempt if you were using X-RAID or certain Flex-RAID levels. However if things aren't in a good state then this may not work.
    Btw there is no RN412. If you're using 3 or more disks (which you'd have to be to be using Flex-RAID RAID-5) then you'll need at least a 4-bay unit such as the RN424.
    • Euschrj's avatar
      Euschrj
      Thank you for your reply.
      As bad as it sounds, I even work in IT and did not backup my own data.  I know that sounds crazy - but it happened.
      I setup this back devices some years ago (probably close to eight years).  I believe i was using X-Raid (since it was default) but seriously cannot remember.  It was a Raid-5 at the time of the incident.  Considering the NAS was not under use when it halted the drives should be in good order.  The drives power up and test ok.
      Sorry, the new model type purchased is the RN214
      https://www.netgear.com/home/products/connected-storage/RN214.aspx#
      • StephenB's avatar
        Do you have some experience with the linux command line interface?
  • Hello community.
    Wanted to share my experience with the board.
    Since my older ReadyNAS 4000 V1 died, i have been trying to regain access to my files.
    NetGear was so kind to assist and for $200 - allowed access to tech support level 3, was actually shipped a ReadyNAS 4000 V2 to "check and see" if it would read the drives.
    Nope no luck,.
    So through various testing with numerous other RAID recovery software, found that reClaime could read the drives and build the directory table perfectly.
    So for another $200., i was able to activiate the software license and regain the files Tech Support 3 nor a V2 ReadyNAS 4000 would allow me to recover.
    Overall, not sure my experience with NetGear Level 3 tech support was somthing i would spend 200 for in the future.  Try reClaime first - save your self the time and trouble dealing the folks on different time zones with little true concern with your need to recover your data.
    PS - leason learned - now have a Bluray burner to backup the raid on a solid medium and an external USB drive for a portable medium.
ProSupport for Business
