carchiba
Jan 07, 2015Aspirant
ReadyDrop keeps going offline
Hi, I have an RN104 running 6.2.2 (just updated but this did not fix my problem). I have ReadyNAS Remote running and use ReadyDROP a lot to synchronise a number of commonly used files/documents bet...
carchiba
Jan 09, 2015Aspirant
Nhellie, thanks for the tips ... I tried the change to port 6300 but this had no effect ... BUT ... I installed the new readyCLOUD backup/sync app as you suggested (I somehow missed that this had been released) and now it works beautifully syncing between my two laptops and the RN104 ... additionally, it is obviously a lot more flexible than the previous readyDROP solution ... thanks again for the tip ... closed.
