Esoteric
Feb 04, 2024Tutor
[ReadyNAS 104] Drives not mounted after repairman took them out.
ReadyNAS 104 Firmware 6.10.5 hotfix 1 Hello, I've had my ReadyNAS 104 for ages now. I use it as storage for old design projects and to make a time machine back up of my iMac. I tried to do ...
Feb 04, 2024Guru - Experienced User
Esoteric wrote:
Without asking, the repairman took out each drive from my ReadyNAS 104 to check if the drives were still good. He says he took out one at a time and put them back one at a time into the same slot, and then it took ages for a system restore.
He did the wrong thing. He should have powered the NAS down before removing the drives, and left it down until they were all returned.
Esoteric wrote:
Is there a way to easily just mount them back correctly? Looks like the data is still there. Not sure why it did this, or how to fix it. I have a download of my logs and can PM the link of them to anyone who needs them.
If you PM me the link, I can take a look. Likely the volume is just out of sync - if that is the case, I can give you instructions on how fo forcibly assemble the array.
Do make sure the link permissions are set so anyone with the link can download.
