ncameron
Apr 21, 2024Aspirant
ReadyNAS 314 Stop Auto Firmware Update
This is legacy hardware, and the last official firmware update (6.10.10) brain damaged key elements of functionality - such as preventing any easy App upgrades. I installed it and then downgraded bac...
Apr 21, 2024Guru - Experienced User
ncameron wrote:
But it keeps auto-updating to 6.10.10.
Go to System->Settings and open up the Update section. Make sure that "notifications for updates" and "automatic firmware updates" are not checked.
ncameron
First thing I did.
No difference. The cunning ****ards want us on 6.10.10 and I’m sure have recorded my initial permission to upgrade and are repeatedly proceeding accordingly…
- StephenBApr 21, 2024Guru - Experienced User
ncameron wrote:
First thing I did.That should certainly do it. Other folks have downgraded successfully, so there must be something else going on with your system.
Maybe try manually uploading 6.10.9 again, then disconnect the NAS from the network. Restart the NAS from the front panel, and see if it sticks at 6.10.9. Then reconnect the ethernet cable.
