JibsMan57
May 19, 2019Aspirant
ReadyNAS Duo v2 - can't see see shares
If this is in the wrong location, apologies and please move it to the correct forum.
I have seen multiple posts about this; none have helped me. After moving I am trying to set up my ReadyNAS D...
- May 19, 2019
Can you check "turn windows features on or off" on the PC? If the SMB 1.0 Client isn't enabled, try enabling it. Then see if you can access the NAS.
Are you using the same router in your new home?
May 19, 2019Guru - Experienced User
