mladen5
Jan 01, 2022Aspirant
ReadyNAS Duo v2 - IP available but won't connect
Hi, I wonder if somebody would know how I can reaccess my readynas duo v2 again, all of the sudden I seem unable to connect to it. RAIDar shows that he status us "Healthy" with the one drive connect...
- Jan 02, 2022
Unfortunately it's the only disk. Nevertheless, I decided to cancel the R-Linux scan which still brought up a red "Rocognized0" volume. I right clicked on this to select "open drive files", and voila! I can view the files in the existing folder structure and recover only those I want to keep. I'll probably bin this one buy a more recent NAS which will hopefully be a tad more reliable.
Thanks for your help though, it is very much appreciated.
Jan 01, 2022Guru - Experienced User
192.168.168.168 is the fail-over IP address when DHCP fails for some reason. It's not compatible with most home network settings.
You say the cable is directly connected to your PC? Is that the usual way you have it set up?
What IP address do you see when it is connected to your router?
- mladen5Jan 01, 2022Aspirant
Thanks for the prompt response, I did try to connect direct to the PC to try to bypass any potential issue with the router (although not sure why there would be as it worked previously). If I connect direct to the router (which is how I've been connecting to it to date), the ip address for the readynas is 192.168.0.15. My local PC ip address is 192.168.0.17 if that makes any difference. I've spent quite a bit of time on it and not sure what else to do. :(
The model is RND-2B if that makes any difference? Failing that, is there a way to read/mount the drive directly via a sata cable so that I can at least retrieve some data from it?
- StephenBJan 01, 2022Guru - Experienced User
does entering \\192.168.0.15 into file explorer give you a different result?
Can you log into the NAS web ui to https://192.168.0.15/admin?
