mattg42
May 11, 2020Aspirant
ReadyNAS Duo v2 refuses to install any Add-on
Hi community, I'm using a ReadyNAS Duo v2, with the current firmware 5.3.13 and I've performed a full disk wipe, hard reset on the system. So I've got 1 x WD 2TB drive in it and its health, so every...
- May 20, 2020The solution was to install the addon using Firefox, for some reason all other browsers give an error using the ReadyNAS web gui. All good and hope this helps someone else.
May 11, 2020Guru - Experienced User
Did you set up the NAS to use a static IP address? If you did, make sure you configured a DNS server (and that the subnet mask and gateway are correct).
mattg42
Hi, I removed the MAC address filter in the router and rebooted the NAS, it now has a true DHCP IP address and default settings. However same error no matter what addin I use for the Duo V2.
It seems like the time it takes to reject / give the error is correlated to the addin complexity. So the SSH enabler is very quick to give the error and the Transmission one is slower, but they all give the same error.
Thanks again
Thanks again
