mattg42
May 11, 2020Aspirant
ReadyNAS Duo v2 refuses to install any Add-on
Hi community, I'm using a ReadyNAS Duo v2, with the current firmware 5.3.13 and I've performed a full disk wipe, hard reset on the system. So I've got 1 x WD 2TB drive in it and its health, so every...
- May 20, 2020The solution was to install the addon using Firefox, for some reason all other browsers give an error using the ReadyNAS web gui. All good and hope this helps someone else.
May 11, 2020Guru - Experienced User
Did you set up the NAS to use a static IP address? If you did, make sure you configured a DNS server (and that the subnet mask and gateway are correct).
mattg42
May 20, 2020Aspirant
