ElChisellero
Apr 08, 2024Aspirant
Readynas Duo v2 status Not-redundant
I'm using a very old ReadyNas Duo v2 which I set up as a redundant pair of disks. However, I have just noticed it is now reporting a status of "Volume C: RAID Level X2, not Redundant. A disk failure ...
Apr 08, 2024Guru - Experienced User
ElChisellero wrote:
I have just noticed it is now reporting a status of "Volume C: RAID Level X2, not Redundant. A disk failure will render this volume dead.;
Both disks are reported as functioning normally.
Is the array syncing?
What firmware is the NAS running?
- ElChiselleroApr 09, 2024Aspirant
How can I tell if it's syncing?
Firmware is 5.3.13
Thanks
- StephenBApr 09, 2024Guru - Experienced User
"Syncing" is re-creating the RAID-1 mirroring - copying the contents of one drive onto the other. If the volume is degraded and NOT syncing, then something is really wrong - generally a failed disk (despite the status you are seeing).
The dashboard should tell you if the NAS is syncing. I'm not sure where though, as I've never owned a v2 ReadyNAS (though I do have other models).
RAIDar will also tell you (one of the disk icons will be blinking).
I suggest downloading the full log zip file from the dashboard. There is a lot of information in there (much more than the web interface shows). If you need help analyzing it, let us know.
If you do not have a backup of the files, then you should make one right away.
Both disks report as healthy on the dashboard, on RAIDar and on the device itself - no blinking lights.
I can't see anything on dashboard about sync status.
The log contains a number of historic reports of uncorrectable errors on both disks, although the most recent log is "Volume scan found and corrected errors".
So I guess I need two new disks and somewhere to dump everything in the meantime?
Thanks
