notsofast
Jan 04, 2022Tutor
ReadyNAS Duo V2 UI is corrupted
I moved and did not use my Duo V2 for awhile. I did a factory reset, the NAS works but the browser UI is missing lots of functions. Under Overview, Service Network and Volumes never show anything. It...
- Jan 04, 2022
OK, that was it! Thank you, sometime just a little human connection can make a big difference <3
I overrode the certificate error in Chrome and it workes like magic. Thank you <3
Jan 04, 2022Guru - Experienced User
what browsers have you tried?
- notsofastJan 04, 2022Tutor
Thanks for the reply.
Thus far only Safari, there is a certificate problem that I could override with Safari but haven't figured out how to override with Chrome.
NET:ERR_CERT_INVALID
I think there could be an issue with the time setting, the wizard was failing in the beginning and now I haven't been able to find the time setting.- notsofastJan 04, 2022Tutor
