SpencerMKE
Oct 06, 2022Follower
Readynas Failed Raid with iScsi
I have a Reaynas Pro 6 with a failed array after a firmware update. I was able to extract out the c.c.dsk image from the raid, good thing it wasn't corrupt, just broken in the readynas software. My i...
Dec 10, 2022Guru - Experienced User
SpencerMKE wrote:
or some type of recovery I can do on the readynas and force the raid array online?
Not sure if you are still facing this issue or not. But if the array is simply out of sync, you can boot the NAS in tech support mode, and manually force it to assemble.
