revvin76
Jul 26, 2012Aspirant
ReadyNAS iSCSI Initiator - setup
Hi there I have a Windows SBS Server 2k11 and a ReadyNAS DUO. I need to set up Windows Backup to use the ReadyNAS, and the only way it seems possible, is to install and setup an iSCSI initiator addon...
mdgm-ntgr
Jul 26, 2012NETGEAR Employee Retired
Hi.
I have the add-on and have used it a bit and it works for me.
How did you edit the /etc/ietd.conf file? Did you use the "vi" command or some other method?
EnableRootSSH enables SSH access for the 'root' user not telnet. SSH is secure whereas telnet is not.
Welcome to the forum!
