revvin76
Jul 26, 2012Aspirant
ReadyNAS iSCSI Initiator - setup
Hi there I have a Windows SBS Server 2k11 and a ReadyNAS DUO. I need to set up Windows Backup to use the ReadyNAS, and the only way it seems possible, is to install and setup an iSCSI initiator addon...
revvin76
doh.... yup I am a complete noob when it comes to ssh and linux. I was brought up on MSDOS and Windows ;)
I am using Putty to ssh as root into the unit.
I havent edited the ietd.conf file - but listing the dirctory shows the default file does exist. The guide only seemed to give instructions for downloading a default configuration so didnt realise it needed amending.
How do I edit/view the conf file on the command line... and what should I be looking for?
And thank you for the response and the welcome to the forum :)
thanks again
kev
thanks again
kev
