revvin76
Jul 26, 2012Aspirant
ReadyNAS iSCSI Initiator - setup
Hi there I have a Windows SBS Server 2k11 and a ReadyNAS DUO. I need to set up Windows Backup to use the ReadyNAS, and the only way it seems possible, is to install and setup an iSCSI initiator addon...
mdgm-ntgr
Jul 26, 2012NETGEAR Employee Retired
Have another look at the instructions they tell you what to add.
You can add it using "vi". The MAN page (google for this) for "vi" explains how to use it.
To open the file for editing you would do:
# vi /etc/ietd.conf
