revvin76
Jul 26, 2012Aspirant
ReadyNAS iSCSI Initiator - setup
Hi there I have a Windows SBS Server 2k11 and a ReadyNAS DUO. I need to set up Windows Backup to use the ReadyNAS, and the only way it seems possible, is to install and setup an iSCSI initiator addon...
revvin76
Ok thank you. I'll be able to figure out the VI command. Have found a couple of guides to help me with syntax.
Looking at the example conf file... it looks as though I only really need two line? the others are all remarked out..
The IQN needs to be globally unique, but the NAS box is sitting inside the firewall and not accessible via the internet - so does it matter whether the IQN is globally unique? Does the name get looked up?
I think I need to add the following lines:
Does this look right?
I really appreciate your guidance,
many thanks,
Kev.
Target iqn.2012-07.uk.co.drewclark:readyduo.iscsi.target0
Lun 0 Path=/c/iscsi_0,Type=fileio
many thanks,
Kev.
