revvin76
Jul 26, 2012Aspirant
ReadyNAS iSCSI Initiator - setup
Hi there I have a Windows SBS Server 2k11 and a ReadyNAS DUO. I need to set up Windows Backup to use the ReadyNAS, and the only way it seems possible, is to install and setup an iSCSI initiator addon...
revvin76
Jul 27, 2012Aspirant
Yes i checked and its definitely in that folder. I didnt check in Windows admittedly, as it looked as though the service wasn't actually starting. I will check now though.
