revvin76
Jul 26, 2012Aspirant
ReadyNAS iSCSI Initiator - setup
Hi there I have a Windows SBS Server 2k11 and a ReadyNAS DUO. I need to set up Windows Backup to use the ReadyNAS, and the only way it seems possible, is to install and setup an iSCSI initiator addon...
revvin76
Jul 30, 2012Aspirant
Anybody else perhaps have any suggestions? I am sure its probably something simple I have missed - but i have no prior knowledge of any of this unfortunately :(
Anybody able to help me troubleshoot why the service doesn't seem to be starting on the ReadyNAS? Is it something I have done with the config file? Perhaps the IQN needs to be resolvable over the internet?
Should it work in a closed environment?
I can ping the ReadyNAS, and SSH onto it from the Windows Server. I suspect the issue is something stopping the service starting on the ReadyNAS - but with pretty much zero knowledge of Unix/Linux commandline I really have no idea where to start? :(
Thanks guys
kev
Thanks guys
kev
