revvin76
Jul 26, 2012Aspirant
ReadyNAS iSCSI Initiator - setup
Hi there I have a Windows SBS Server 2k11 and a ReadyNAS DUO. I need to set up Windows Backup to use the ReadyNAS, and the only way it seems possible, is to install and setup an iSCSI initiator addon...
mdgm-ntgr
Oct 05, 2012NETGEAR Employee Retired
The iSCSI add-on is for the Duo (v1) not the Duo v2. That's why it won't install on your Duo v2.
