revvin76
Jul 26, 2012Aspirant
ReadyNAS iSCSI Initiator - setup
Hi there I have a Windows SBS Server 2k11 and a ReadyNAS DUO. I need to set up Windows Backup to use the ReadyNAS, and the only way it seems possible, is to install and setup an iSCSI initiator addon...
OOM-9
Oct 29, 2012NETGEAR Expert
Mario is correct, the Duo v2s will not have the iSCSI support.
There is an option between the Pro and Duo v2.... The Ultra will have the iSCSI support.
