hengy1
Jan 31, 2021Tutor
Readynas NV Dead Power Supply
Not sure if this is posted in the right place. But I've just spent a lot of time trying to resurrect my aged but still working well readyNAS NV storage unit. It wouldn't power on. I've replaced the p...
- Jan 31, 2021
All I care about is that I fixed the problem. It works. I couldn't care less the age of the unit. It works.
mdgm
Jan 31, 2021Virtuoso
Considering the unit could be as much as almost 15 years old if you hadn’t replaced the coin battery before it’s hardly surprising that that failed.
With a failed PSU usually after removing the PSU you would see burnt capacitors or even before removing the PSU you may notice a burning smell.
