PCJB
Apr 10, 2023Aspirant
ReadyNAS NV+ SSH Access problem - my fauly!
OK My fault! I have had my ReadyNAS NV+ working fine for years and use SSH remote root access to fix problems as necessary. Today I did a stupid thing. I SSHd into the ReadNAS and then wanted to S...
- Apr 10, 2023
Thanks to all. I’ve fixed it and all is ok now.
some Googling discovered that there is a serial port on the back panel, under the little screwed plate that is the console port.
There are two rows of 0.1” pins one has 6 pins and the other has 4. The internet info indicated that the 4 pins were 3.3v TTL RXD & TXD. A meter showed the pin outs at 3.3V RXD TXD GND from Left to Right when looking at the pins. Using a USB 3.3v TTL dongle plugged (Dongle TXD to NV+ RXD, Dongle RXD to NV+TXD , GND to GND, 3.3v not connected.) at 9600 8N1 XON/XOFF and pressing CR gave me a login prompt!! logged in and fixed the error and all working again.
Thanks again. Hope this helps someone else.
Apr 10, 2023Guru - Experienced User
PCJB wrote:
I was wondering if there was a way of maybe editing a phpscript from the website to invoke the nano editor on the server to enable me to edit the file?
Also would simply reinstalling SSH Root access from frontview rewrite the sshd_config file?
Maybe, but I think the only way to tell is to try it.
An OS reinstall from the boot menu might possibly work.
A factory default would of course work, but would reformat the disks - so you'd lose your data, and you'd need to reinstall your add-ons.
