PCJB
May 25, 2023Aspirant
ReadyNAS NV+ USB drives for Backup?
My ReadyNAS NV+ ( ARM) has 1MB RAM and 4*2TB drives in a RAID array. I have a 2TB external Hardrive for backups. The Backup drive has started to have problems and I have purchased a replacement 3TB s...
- May 26, 2023
No, you cannot. MBR limits the full amount of the drive that's available, not just a single partition.
May 25, 2023Guru - Experienced User
PCJB wrote:
My ReadyNAS NV+ ( ARM) ... Frontview (V4.1.16) s
If you are running 4.1.16 firmware, then you have the original (Sparc-based) NV+, not the later ARM platform.
The original NV+ (v1)
- says ReadyNAS NV+ on the front panel
- runs 4.1.x firmware
- uses a Sparc processor
- often has labels on the back or bottom that say v2 or v3. These don't mean what you think they mean. They just identfity minor hardware revisions.
The NV+ v2
- says ReadyNAS NV+ v2 on the front panel
- runs 5.x firmware
- uses a ARM processor
PCJB wrote:
When I first installed it, Frontview (V4.1.16) showed its size as 2048MB, even though its a 3TB drive. I presumed this was because the NV+ only supports drives upto 2TB in size.
4.1.x systems are limited to drives of 2 TB or less. If you install larger internal drives, the size will always end up 2 TB or less - the arithmetic that computes the volume size overflows, so it's a bit hard to predict. But normally you will end up with about 746 GB per drive (volume size for 4x3TB RAID array then ends up about 2 TB, instead of 12 TB).
USB drives are also limited to 2 TB
PCJB wrote:
So I am wondering if I partitioned the 3TB drive into two partitions would the NV+ recognise them as two separate USB drives like /USB_HDD_10 and /US_HDD_11?
I don't think so, as the NAS only supports MBR formatting, which is limited to 2 TiB.
PCJB
Hi StephenB,
Thanks for the clarity. Its a while since I delved into the innards of my NV+. I knew it wasnt the X86 version!
You are of course right in that its the sparc version not the ARM one.
Do you know whether I can partition my USB drive into two partitions and whiether they would be mounted OK?
- SandsharkMay 26, 2023Sensei
