ablamboo
Apr 11, 2012Aspirant
ReadyNAS NV+ V2 and Media Entertainer Express EVA9150
So I got a new ReadyNAS NV+ V2 for two reasons: 1-I wanted to continue using Logitech Squeezebox to stream music and 2-To continue to stream videos to my Netgear Media Entertainer Express EVA9150. No ...
Apr 12, 2012Guru - Experienced User
You can enable "live folder browsing" on the EVA9150. (I think its in the advanced->other settings menu).
Also, if you select a subfolder from the EVA and press 'eject" on the remote, the EVA will do a quick scan of that folder. Not a good workaround of course, but sometimes it comes in handy.
