sabbybali
Oct 04, 2017Aspirant
ReadyNAS NV V2 wont power on (ReadyNASRND4000v2)
Hi All, I have a ReadyNAS RND4000v2 and I think it got fried due to power outage we suffered in street. Out of warranty for sure as it was purchased back in 2012, no support either. Symptom ...
- Oct 04, 2017
sabbybali wrote:
I was running RAID-1 with two disks, but having 4 disks in NAS. So I get total of 6 GB mirrored storage.
Ok. If you have two RAID-1 volumes, then try R-linux for Windows (free utility). http://www.r-tt.com/free_linux_recovery/
sabbybali
Hi StephenB,
Responses as below:
You are booting on a Linux PC?
No, It is a windows 10 laptop, with diskinternals software installed on it; and some modules such as partition recovery, NTFS recovery etc. Don't have license for raid recovery.
Were you running RAID-1 (or XRAID) with two disks? If not, what RAID mode are you using?
Thanks,
Sabby
Oct 04, 2017Guru - Experienced User
- sabbybaliOct 04, 2017Aspirant
Thank you StephenB,
I will get this and gett my work going for now; and this will buy be some time to research for new NAS system.
Thanks a lot for the help.
Sabby
StephenB wrote:
sabbybali wrote:I was running RAID-1 with two disks, but having 4 disks in NAS. So I get total of 6 GB mirrored storage.
Thank you Stephen,
I am able to recover my files and get my work going.
Many thanks for guidance.
Sabby
