mhyoung
Sep 18, 2023Aspirant
ReadyNAS NVX 4000
Hello everyone, I'm sure this has been discussed a million times, but I would really appreciate some advice or direction on what to do. I have an older NAS unit RNDP4000 - ReadyNAS Pro 4 firmware...
Sep 18, 2023Guru - Experienced User
mhyoung wrote:
I had a drive go bad and I replaced the drive yesterday. The software picked it up and was performing the resync and I went to bed. I woke up this morning and drive 1 is now a spare, drive 3 is dead, and drives 2 and 4 are ok.
What happened?
Possibly disk 3 failed in the middle of the resync. Are you seeing any errors to that effect in the logs?
mhyoung
Honestly, I haven't had time to go through them and I'm not sure what I'd be looking for, but I plan to go through them later tonight after the kid's homework etc.
If #3 did fail during the re-sync would that mean that the volume is lost?
Thanks for the quick response to an old product!
- mhyoungSep 19, 2023AspirantOne more thing I don’t understand is that the front view shows 0TB as the amount of storage but the screen on the nas unit shows 5.9TB of 10TB available.
Is this hopeful?
