StuBarrett1
Jun 17, 2019Aspirant
ReadyNAS Pro will not power on
Please help. I have a ReadyNAS raid storage unit Business/Pro model RNDP6000 with 6 disk slots. I returned from vacation to find my AC had quit and the house was very warm. I used the fron...
- Jun 18, 2019
StuBarrett1 wrote:
... the CMOS battery was pulled during the debug process so I lost the CMOS settings. ... Is that equivalent to a "factory reset"?
The CMOS battery only keeps the real time clock ticking - which is needed for the power schedule feature.
So you haven't lost anything.
StuBarrett1
Jun 20, 2019Aspirant
OK, got a new power supply and things look good. Boots and the data is still good!!
Thanks for you help!!
OK, So I'm going to buy a new ReadyNas since my current one is getting on, and I need to upgrade anyway. I'm taking Marc_V advice and buying a RN426 or an RN526 (I'm leaning towards the 526).
I've been using HGST UltraStars since they are supposed to be the most reliable but I have seen reccomendations for the Seagate IronWolf NAS drives for being especially suitable for NAS units. I've looked at the disk compatibility informaton and both types are supported, but I was looking for a thread that discusses the different quality of NAS specific drives and cound not find one (search failure?). I was wondering if such a discussion (or other source) would help me make an informed choice?
Thanks, Stu
StuBarrett1
I did find this resource: https://www.backblaze.com/blog/hard-drive-stats-for-2018/
Is there any discussions on this forum?
Stu
- StephenBJun 21, 2019Guru - Experienced User
There have been some discussions on drive choices. BackBlaze is a reasonable source, but it is important to keep in mind that their pods are quite different from most NAS.
I don't recommend desktop drives - NAS-purposed or enterprise drives are better choices.
Personally I use WDC Red drives (though I have a couple 1 TB Ironwolf drives also). Generally speaking, there aren't a lot of issues reported with either WDC Red or Ironwolf posted here (though I have noticed two or three posters seeing some failures with the WD60EFRX lately - including me).
