matejk1
Oct 20, 2011Aspirant
ReadyNAS Remote + Hamachi = Problem
Can anybody else confirm that having the Logmein Hamachi Client installed alongside ReadyNAS Remote client creates problems with ReadyNAS Remote ? After a day of going through the steps in various ...
matejk1
Nov 22, 2011Aspirant
Glad that my info helped you!
In the meantime I could confirm 100% that Hamachi was indeed causing problems for ReadyNAS Remote. There is no need to uninstall Hamachi, just disable the Hamachi network adapter + stop the Hamachi service (so if later you need Hamachi just restart the service and you're done).
M.
M.
