Damien89
Sep 19, 2014Aspirant
Readynas remote connecting but no shares visible
Hi. both my iphone and ipad readynas remote apps can connect but i cant see any shares, i'll include a photo to show what i'm seeing.
Thanks
Thanks
- metrixtechAspirantAre you saying there has been a recent update to the ReadyNAS Remote app for the iPhone and iPad? I have been using v. 1.5.8 and it seems that version has been around quite awhile. The reviews in the App Store have not been that good, but I thought I was one of the lucky ones. I'm still completely puzzled while something works one day and not the next.
How long were you using the ReadyNAS Remote app on your iPhone and iPad before it crapped out? - Damien89Aspirant
metrixtech wrote: Are you saying there has been a recent update to the ReadyNAS Remote app for the iPhone and iPad? I have been using v. 1.5.8 and it seems that version has been around quite awhile. The reviews in the App Store have not been that good, but I thought I was one of the lucky ones. I'm still completely puzzled while something works one day and not the next.
Actually i hadn't used it in some time, i am not sure if the last update is the culprit - Damien89AspirantI could be mistaken regarding the problem occuring with the update because i checked the update and its listed as being launched last may.
- Damien89AspirantWent to check one of the downloads in the app and their all gone!! Whats happening to this app??
- JijonesGuideI get the same thing
- I have the same issue on iPhone and iPads
Problem occurred sometime in the past few weeks - I have updated to iOS 8 on all devices
Don't know if the problem began then
PC works after I upgraded to the newest P2P
This was also a challenge to find and upgrade
Installing replicate installed the newer version of P2P
PC did not work without beginning about a week ago - Damien89Aspirant
MurrayMartin wrote: I have updated to iOS 8 on all devices
So your iphone and ipad's readynas remote app started working again after you upgraded to ios8? - BrookHamptonAspirantSame issues with my iPhone.
My iphone app "filebrowser" works without issue and connects to the readynas fine. I have an old Spark Duo V1 - parkercAspirantJust adding my name to this issue, I have the same view as @damian89
It seems to connect but cannot see the ftp shares
Ive tried to remove the account and re-add it but no joy, restarts are no good either.
Is this Netgears way to say buy a new NAS?
I'm using the original Duo.
