Mills
Nov 27, 2011Aspirant
ReadyNAS Remote Duo V2 installation
I recently purchased a ReadyNAS Duo v2 and when I go to the add on tab to install readynas remote and click "get" a message comes up saying installation in progress, please wait for confirmation. I have waited over a day and it still says this. I have also done a factory reset and the message is still coming up. Please let me know if there is any additional information I can provide to solve this problem.
- mdgm-ntgrNETGEAR Employee RetiredIt should install fine. After attempting to get the add-on what do you see under Health > Logs after say 15 minutes?
If you have email alerts configured do you get an email about successful add-on installation?
If you clear your web browser cache (e.g. Temporary Internet Files in Internet Explorer or Safari > Empty Cache in Safari) close your web browser then reopen the dashboard and click configure do you see Remote under Add-ons > Installed? - MillsAspirantAfter performing the factory reset system log says the follwing.
Sun Nov 27 18:42:24 EST 2011
Alert settings saved.
Alert contact(s) saved.
Sun Nov 27 18:40:49 EST 2011
Sun Nov 27 18:35:07 PST 2011
System is up.
Sun Nov 27 18:34:12 PST 2011
Successfully installed ReadyNAS Photos II addon package (version: 1.0.5-T7)
I cleared the browser cache and cookies and after logging into the readynas and then the add-ons tab. The readynas remote add on is still listed under the available add-ons. If I click get I am still getting the same message saying that installation is in progress, please wait for confirmation. - wasted_dAspirantI have the same problem with Readynas remote not installing on a my Duo v2.
After clicking on the add button there is nothing added to the health logs.
I have factory reset the DUO v2, wiping both my 2x2tb drives and setting up from scratch but still no go with installing readynas remote. - sschneidAspirantSame problem - seems consistent.
- mdgm-ntgrNETGEAR Employee RetiredWhat web browser are you using?
Have you tried a different web browser? - wasted_dAspiranti use chrome but i have also tried it with firefox 6.02 and ie 9.08
none help with gettin this to work. - MillsAspirantI mainly use Chrome but I have tried IE and I am still getting the same results.
- wasted_dAspiranti should add when i first got my readynas duo V2 this installed with no issues but then i had reason to do a factory restore ( i added previously formated disks) and since doing this restore readynas remote wont install. Other than that nothing is any different from the first time it did install.
- mdgm-ntgrNETGEAR Employee RetiredDid you delete the partitions (e.g. using a PC) on those previously used disks before adding them?
- MillsAspirantThe drive I am using was originally sold as an external hard drive so as far as I know there weren't any additional partitions. However I was under the assumption that once a factory reset was performed the drive would be reformatted anyway.
