jwr11
Jun 12, 2010Aspirant
ReadyNAS remote install problems
Hello,
I am unable to install the ReadyNAS remote software on a PC running Windows 7.
I am guessing the problem is the leafnetworks adapter. I also tried doing a manual install of the adapter with no luck as well. I tried with the AV turned off and in SAFE mode.
Thanks in advance for your help.
Install Info:
Create folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NETGEAR ReadyNAS
Output folder: j:\NETGEAR ReadyNAS\Remote\bin
Create shortcut: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NETGEAR ReadyNAS\\ReadyNAS Remote.lnk
Windows Version is 7
Output folder: C:\Windows\system32
Output folder: C:\Windows\system32\drivers
Output folder: j:\NETGEAR ReadyNAS\Remote\adapter
Extract: FwHookDrv.sys... 100%
Extract: fwleaf.cat... 100%
Extract: fwleaf.sys... 100%
Extract: fwleafm.inf... 100%
Extract: fwleafp.inf... 100%
Extract: leafnets.inf... 100%
Extract: leafnets.sys... 100%
Extract: tap.cat... 100%
Output folder: j:\NETGEAR ReadyNAS\Remote\adapter\x64
Extract: DataModelBase.dll... 100%
Extract: FileShare.xml... 100%
Extract: Interop.EventSystemLib.dll... 100%
Extract: Interop.NetFwTypeLib.dll... 100%
Extract: Interop.SensEvents.dll... 100%
Extract: LeafFolder.ico... 100%
Extract: Libnet.dll... 100%
Extract: PacketRoutingPlugin.dll... 100%
Extract: ReadyNASRemote.exe... 100%
Extract: ReadyNASRemote.exe.config... 100%
Extract: SetAdapterHidden.vbs... 100%
Extract: WindowsMediaShare.xml... 100%
Extract: XBoxShare.xml... 100%
Extract: addLeaf.vbs... 100%
Extract: gacutil.exe... 100%
Extract: hstorage.lfn... 100%
Extract: lnSidLibrary.dll... 100%
Extract: lnThreadPool.dll... 100%
Extract: lnadptrcnfg.dll... 100%
Extract: lnadptrcnfgx64.dll... 100%
Extract: lncomservice.dll... 100%
Extract: lninitadapter.dll... 100%
Extract: lnmodel.dll... 100%
Extract: lnp2p.dll... 100%
Extract: lnp2padapter.dll... 100%
Extract: lnp2pclient.dll... 100%
Extract: lnp2penc.dll... 100%
Extract: lnp2pfilter.dll... 100%
Extract: lnp2pnative.dll... 100%
Extract: lnp2pnotification.dll... 100%
Extract: lnpluginmngr.dll... 100%
Extract: lnprotocolhandler.dll... 100%
Extract: lnregasm.exe... 100%
Extract: lnresources.dll... 100%
Extract: lnscrunner.exe... 100%
Extract: lnshplbr.dll... 100%
Extract: lnshrcontainer.dll... 100%
Extract: lnshrmngr.dll... 100%
Extract: lnutils.dll... 100%
Extract: logo.ico... 100%
Extract: msvcr71.dll... 100%
Extract: one.vbs... 100%
Extract: options.config... 100%
Extract: packet.dll... 100%
Extract: pthreadVC.dll... 100%
Extract: setp2padapterip.dll... 100%
Extract: svcutil.dll... 100%
Extract: wpcap.dll... 100%
Output folder: j:\NETGEAR ReadyNAS\Remote\bin\plugins
Output folder: j:\NETGEAR ReadyNAS\Remote\bin\plugins\list
Output folder: j:\NETGEAR ReadyNAS\Remote\docs
Output folder: j:\NETGEAR ReadyNAS\Remote\docs\license
Extract: license.txt... 100%
Output folder: j:\NETGEAR ReadyNAS\Remote\docs\release notes
Extract: Release Notes.txt... 100%
Installing network adapter leafnets.sys (amd64)...
No devices were removed.
Device node created. Install is complete when drivers are installed...
Updating drivers for leafnets from j:\NETGEAR ReadyNAS\Remote\adapter\x64\leafnets.inf.
lnadptrcnfgx64.dll failed.
Done
Adjusting network adapter (amd64)...
Install Info:
Done
- muertAspirantthanks for information
- claykinAspirantTry new version of Readynas Remote. https://remote.readynas.com/download.html
- cateyedAspirantHi all,
I stumbled across this post when I was having this problem also. I also had VMWare and Virtual Box installed. Since I don't need them, I have removed them, and the install completed successfully (even without a reboot).
Just thought I'd post in case this helps someone else.
Cateyed - avinjeAspirantI have the same problem on my Sony Vaio laptop.
I am -not- running VMWare or any other virtual machine, and I am using the latest version of ReadyNas Remote.
If fails during the install process at "Adjusting network adapter (amd64)..." (hangs).
Does anyone know of any fix for this problem?
Also hoping Netgear will rectify this problem in the next version of this software... - MaxKoNETGEAR ExpertWindows 7:
Let's try to do this:
Find in system register,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\MaxNumFilters
and increase current value for 1. - vyperzAspirantI had this exact problem. After ages searching and trying different things, I went to Leaf Networks and downloaded the latest software :
http://www.leafnetworks.net/download.html
Then installed it , and it installed ok. Then I uninstalled and reinstalled ReadyNAS Remote , and it then worked.
My system is running Windows 7 Professional (32 bit )
