viktor77796's avatar
viktor77796
ReadyNAS RNDP6000 RND-6B stuck at "ReadyNAS" state when turned on
Good day!   There is a problem - ReadyNAS RNDP6000 RND-6B freezes at "ReadyNAS" state when turned on.  According to the owner of the device, first the raid disappeared, then the disks were disconn...
  • Sandshark's avatar
    Sandshark
    Nov 28, 2024
    You need 3 4-pin Molex and, except for the pre-modified one I mentioned, you aren't likely to find that on an SFX supply.  I typically remove the 90° connectors from the old one and move them to the new, which also allows me to trim some excess cable.  But a Y adapter and/or SATA to Molex adapters will also give you that.  Then, yes, you need the longer main cable or extension.  A 15mm or so extension is usually right, but you may want to wait till you have the supply and see what you are going to need.  The original supply has 22.5A available on the two 12V rails combined, and you are unlikely to find a supply under 400W that can deliver that.
ProSupport for Business
