bgottschall
Mar 10, 2022Aspirant
ReadyNAS Ultra 4
I have a ReadyNAS Ultra 4 running RAIDiator 4.2.31. This unit will be deprecated when IE is no longer usable as new browsers cannot communicate with the device. I would like to update the device to...
- Mar 11, 2022
bgottschall wrote:
1. When you say backup, I assume you mean backup to some other local storage off the NAS as the unit will factory reset and wipe the installed disks in the described process. Is that correct? This may be the end of the road for me as I do not have adequate storage on hand elsewhere to accomplish this.
Correct. As an aside - RAID isn't enough to keep your data safe, So you might want to look into backup options whether you decide to convert the NAS or not. USB drives are one approach (either connected to the NAS, or connected to a PC).
bgottschall wrote:
2. I was unaware the unit could have its RAM increased. Is there a specification published for the RAM I need? Should the RAM be upgraded before any other step listed below or after the unit is at OS6 if I go that way?
200-Pin DDR2 SODIMM DDR2 667 (PC2 5300) should work. The Ultra 4 has only one slot - it can take up to 4 GB modules, though 2 GB is enough.
bgottschall wrote:
Starting to think I may just buy a new NAS and copy the contents of this one to that unit while it is still acccessible.
The add-on for 4.2.x systems should avoid that problem for now.
bgottschall
Mar 11, 2022Aspirant
Thank you!
A couple follow up questions...
I really appreciate the advice on this!
Mar 11, 2022Guru - Experienced User
