red_maryandred_
Sep 04, 2011Follower
Remote Client starting/stoping -- will not initialize
Hello: I have the lastest version of the client installed and the latest version of the add-on installed. When I start the client on my Windows 7 machine it appears to attempt to log-in and then w...
adrian_jenkins
Nov 17, 2011Aspirant
Doesn't make any difference :(
i have tried on a HP with Win7 Pro 64Bit SP1 and Symantec Endpoint Protection and an IBM with Win7 Pro 32bit SP1 and Microsoft Security Essentials. When the program tries to log in to the server it crashes. if you have "log in automatically" ticked, the program goes into a cycle of logging and crashing and you have to get in quick to the properties to turn that function off.
is there a set of ports and IP addresses that need to be open for this program to work? if that port is not available would the program crash?
