Bante
Aug 06, 2010Aspirant
remove webroot and addons-config netshare
I've been trying out some community addons and I didnt use them as much so I removed them. The removal worked great but for some reason my computers can still see shares that have been created by ...
super_poussin
Jan 19, 2011Virtuoso
wirewizard wrote: I am having the same issue, I have removed the webroot and addons-config shares manually in frontview after removing the transmission addon. The shares are there, but they are not accessable.
I also tried the bin file you posted to remove the directories, still the shares are there. it's not a windows cache issue as I can see these shares on my android phone.
I logged into the box via SSH and checked the Shares.conf located in /etc/frontview/samba/Share.conf and this only shows the shares that are supposed to be there (videos, music, pics, other), not the 2 shares that are unremovable after installing transmission. Also in /c/ these folders are not apparent, neither are they apparent on the root, yet if I run an mkdir and create these folders in either /c/ or the root, the shares are usable again, unfortunately, this share then does not show up in frontview to delete it.
I'm not sure what I should do next, but I have near 1.5tb of data that I cannot factory reset as I don't have another home for it to go to at present. Is there a solution for this?
can you provide me ssh access ? If yes PM me
