Imem
Dec 14, 2011Aspirant
HELP! Accessing addons-config and more
Humm i am about to change settings for Transmission and i try to access addons-config but i cant access it it ask me for password and admin 'xxxx'
where xxxx is my set password for user admin
What is the password and how do i get access to it?
The same for Root!
The same for Root!
- Mr_BGuideI'm sorry, i'm not sure i understand what your asking, really. But i'll try my best to answer. The addons-config share is accessed with the admin password for the NAS. I suppose the same is true for the root.
I had an issue where 64bit Windows XP wouldn't let me log on, regardless, sorted by using a laptop with regular XP on it... Might have been a fluke, no idea.
B! - ImemAspirant
Mr_B wrote: I'm sorry, i'm not sure i understand what your asking, really. But i'll try my best to answer. The addons-config share is accessed with the admin password for the NAS. I suppose the same is true for the root.
B!
Humm my be the same for me then i try my laptop with Ubuntu on it!
(Win7 64bit) - ImemAspirantno luck there and i am using the right password!
I tried using a Vista computer to...
do i need to set up users some how? - ImemAspirantApparently you need to set a new password for those 2 maps!
I did that under share's tab.
You learn some thing every day :-D - Mr_BGuideCool. That didn't do jack squat for me, but i'm glad you got it worked out.
B!
