Bante
Aug 06, 2010Aspirant
remove webroot and addons-config netshare
I've been trying out some community addons and I didnt use them as much so I removed them. The removal worked great but for some reason my computers can still see shares that have been created by ...
VNY
Jun 01, 2011Aspirant
mdgm wrote: "home" and "c" are only seen if you login as "admin" (Frontview user). Don't login as "admin" if you don't want to see those shares.
You could try installing the CreateMissingSharePaths add-on. Then delete the shares you want to delete via Frontview. This should remove the entries for the shares in /etc/frontview/samba/Shares.conf
In /etc/frontview/samba/addons you should delete the relevant entries from the addons.conf file and the conf files for the shares created by addons you want to delete such as "addons-config.conf"
Then reboot the NAS to verify the problem is fixed.
OK...Update
I went in SSH using Putty and deleted webroot.conf and addons-config.conf...that did that. By the way... the CreateMissingSharePath restored the "backup" folder
Now...the only thing that exists is "C" and "Home" showing up on my PC's Network Path; Ex; Readynas (NAS).
Well..I never saw the "C" and "Home" shares until I read something and then selected "User" from Radiator Security Mode. Changed it back to "Share" but "C" and "Home" remained. I haven't logged in any differently; like you stated as "admin" so I cant see whats happening there.
I appeciate all the help
