newbuilder
Dec 25, 2011Aspirant
replicate both ways?
I would like to buy another Netgear duo and replicate it across the web to another location. Easy enough according to the notes. Is this a free add-on? However, is there a way that I can have the ...
mdgm-ntgr
Jul 06, 2012NETGEAR Employee Retired
You need to purchase licenses for Replicate. One for each NAS.
Home licenses for Duo/NV+ v2
Desktop licenses for Ultra/Pro
Rackmount licenses for rackmount x86 ReadyNAS i.e. 2100/1500/3100/3200/4200
Replicate is not available for Duo/NV+ v1 which presumably newbuilder has based on forum join date.
There is a free trial for Replicate should you wish to try before you buy.
