rickyhumby
Jan 03, 2013Aspirant
REPLICATE CANNOT INCREMENT LARGE FILES OFFSITE
I have the following setup. 1. Client has a Duo V2 on site. Latest firmware and drivers and Replicate. 2. Windows 2008 server backup to the onsite NAS (Duo) 3. Backing this up to NAS in data ce...
rickyhumby
Jan 08, 2013Aspirant
If it helps wdrumheller - I have tested it with flat files - and they replicate perfectly. As long as you do the first backup with both NAS on the same LAN, then any subsequent replicate jobs offsite will be perfect - it will only send the changed files.
Having said that, original problem still exists - if it does see a difference in a file - it will copy the whole file offsite. Fine is word docs - useless if it is a 10GB backup file...
Netgear have advised me Replicate is 3rd party and they don't develop it - but when I login it says "NETGEAR" all over it. What a cop out from Netgear - and I hope others read this because REPLICATE is not suitable for using one nas as a windows backup target - and then replicating it offsite. It does NOT do this - however I assumed it did looking at the documentation. IT DOESNT. What it does do is mirror one NAS offsite if it has a lot of SMALL files on it. ANY LARGE files and you'll never get them offsite in any kind of window.....
