kennywan
Jan 20, 2016Aspirant
Replicate can't see volumes in devices #26347858
Hi,
Both my devices have been added to replicate but when trying to select backup data or backup system, i can't see volumes in either devices. I had a replicate job setup and it started failin...
JennC
Jan 20, 2016NETGEAR Employee Retired
Hello kennywan,
Please let us know the model number of the NAS units and their current FW version. If you can post a screenshot, please do.
Did you also try another web browser? Are the 2 NAS units in the same network?
kennywan
I have two ReadyNas 2100, one local and the other at our DR site. I upgraded both firmware to 4.2.28, replicate version 1.20.
I was using IE. I used Firefox and now can create the jobs and see the volumes. After I setup a system and back data job, i am getting the following error:
[2016-01-20 08:07:26] [Info] Replicate version: 1.2.0 build R1
[2016-01-20 08:07:26] [Info] Starting backup job "System Backup [2016-01-20 07h 59m AM]"
[2016-01-20 08:07:26] [Info] Locking target folder: /c/System Backup 2016-01-20/System Backup [2016-01-20 07h 59m AM]
[2016-01-20 08:07:26] [Info] Resume folder is "/c/System Backup 2016-01-20/System Backup [2016-01-20 07h 59m AM]/2016-01-20 08-01 (failed)/data"
[2016-01-20 08:07:27] [Info] p2p connect to viterbistorage1 in 9500056 network
[2016-01-20 08:07:27] [Error] Unable to connect to viterbistorage1
[2016-01-20 08:07:27] [Error] Connect error code: -501
[2016-01-20 08:07:27] [Error] Please check network connection between devices
[2016-01-20 08:07:27] [Info] Unlock target folder: /c/System Backup 2016-01-20/System Backup [2016-01-20 07h 59m AM]
[2016-01-20 08:07:27] [Info] Job finished
- kennywanJan 20, 2016Aspirant
- JennCJan 20, 2016NETGEAR Employee Retired
Hello kennywan,
Are the 2 NAS units connected to a switch directly or router?
You might want to see this article: ReadyNAS: Replicate Troubleshooting
- kennywanJan 22, 2016Aspirant
one device is at our local site, other at our DR site. I enabled ReadyNAS remote on both devices and no longer seeing the error, when i try to run the job, i am now seeing a snapshot error. I have tried rebooting but still same error.
[2016-01-22 09:38:25] [Warning] Incremental not possible
[2016-01-22 09:38:25] [Info] p2p connect to viterbistorage1 in 9539247 network
[2016-01-22 09:38:29] [Info] Connection method: 0
[2016-01-22 09:38:29] [Info] LAN connection not available
[2016-01-22 09:38:29] [Info] Using p2p connection
[2016-01-22 09:38:29] [Info] Initializing source device
[2016-01-22 09:38:29] [Info] Sending task to source device
[2016-01-22 09:38:30] [Info] Awaiting task report
[2016-01-22 09:38:31] [Error] Received failed report
[2016-01-22 09:38:31] [Error] Unable to create snapshot for "c"
[2016-01-22 09:38:31] [Error] Device initialization failed
[2016-01-22 09:38:31] [Info] p2p disconnect with viterbistorage1 in 9539247 network
[2016-01-22 09:38:32] [Info] Unlock target folder: /c/viterbistorage/Data Backup - speech arvhice test [2016-01-22 09h 19m AM]
[2016-01-22 09:38:32] [Info] Job finished
