replicant
Dec 02, 2015Aspirant
Replicate error: Unable to connect to non-participating unit
Hi, We have three units and one daily data replication job from Unit1 to Unit2. Now I am trying to start an additional Replicate job from Unit1 to Unit3, on their LAN. All three units appear in...
BrianL2
Dec 02, 2015NETGEAR Employee Retired
Hi replicant,
Can you confirm if this replicate backup (unit1 to unit2) is working before? Consider doing the following:
* For restrictive firewalls and more complex networks, consider setting up port forwarding.
* On unit2, remove Replicate user binded and re-add the NAS to the Replicate account. Then, recreate the backup and try it again.
Kind regards,
BrianL
NETGEAR Community Team
- replicantDec 03, 2015Aspirant
Hi BrianL,
Yes, the Unit1-to-Unit2 replicate job has been working since May and automatically completed another incremental backup this morning. I also had a Unit1-to-Unit3 job working for three years until it started failing Sep3 and never recovered. I figured the incremental backups had overwhelmed the filesystem of Unit3 (Duo v.2). So I reset it to factory default, re-installed Replicate, re-registered it (with you guys' help) and created the Unit1-to-Unit3 job that now complains 'unable to connect to Unit2'.
Regarding your suggestions below, we have no firewall issues: the LAN of units 1 and 3 has always been on plain-vanilla DHCP / NAT behind a cable modem. No reason to set up port forwarding. To 'remove Replicate user binded', I guess means to delete it from the 'Network' panel, right? But if I remove Unit2 in that way, wouldn't that permanently disable use of the (currently working) Unit1-to-Unit2 backup? Would we risk recovery in case something happens to production Unit1 while we are solving this problem (which should only involve 1 and 3)?
One more thing: back in 2012, Capone helped us sort through problems about serial numbers and license keys that originated when we switched unit 1 and 2 and their names. Could today's problem still be some kind of leftover from that fix three years ago?
Thanks again,replicant
