GearManager's avatar
GearManager
Replicate Failure Issue
My replication is failing with the following logs:
[2013-10-03 20:00:02] [Info] Job updated from server
[2013-10-03 20:00:03] [Info] Replicate version: 1.2.0 build R6
[2013-10-03 20:00:03] [Info] Starting backup job "LLO"
[2013-10-03 20:00:03] [Info] Locking target folder: /data/LLO/LLO
[2013-10-03 20:00:03] [Info] Resume folder is "/data/LLO/LLO/2013-10-02 20-00 (cancelled)/data"
[2013-10-03 20:09:22] [Info] p2p connect to nas-80-0D-62 in 1819003 network
[2013-10-03 20:09:23] [Info] Connection method: 1
[2013-10-03 20:09:23] [Info] LAN connection not available
[2013-10-03 20:09:23] [Info] Using p2p connection
[2013-10-03 20:09:23] [Info] Initializing source device
[2013-10-03 20:09:23] [Info] Sending task to source device
[2013-10-03 20:09:28] [Info] Awaiting task report
[2013-10-03 20:09:31] [Error] Received failed report
[2013-10-03 20:09:31] [Error] Unable to create snapshot for "c"
[2013-10-03 20:09:31] [Error] Device initialization failed
[2013-10-03 20:09:31] [Info] Rotate backups (10)
[2013-10-03 20:09:31] [Info] Rotation marker is "2013-08-29 20-00"
[2013-10-03 20:16:49] [Info] p2p disconnect with nas-80-0D-62 in 1819003 network
[2013-10-03 20:16:50] [Info] Unlock target folder: /data/LLO/LLO
[2013-10-03 20:16:50] [Info] Job finished
The replication process is taking place, the target NAS is showing network activity of the transfer as well as writing to the disks yet still fails.
Thoughts? Ideas?
1 Reply
  • This problem was fixed for me by reloading Replicate software... worth a try :)
ProSupport for Business
