macmanleeleap
Oct 28, 2016Aspirant
Replicate issues STILL....
I have 2 readynas usnits runnig the latets firmware and they (after sorting out a p2p issue) backed up fine locally and now I have one unit offsite the backups are failing. Any advice please as I am ...
JennC
Oct 28, 2016NETGEAR Employee Retired
Hello macmanleeleap,
I have some questions to ask, I have summarize them below.
- What is the model number of the ReadyNAS units?
- What is the firmware version of each unit?
- You mentioned, you now have one unit offsite, does that mean you moved one of the units to another network?
- macmanleeleapOct 31, 2016Aspirant
Cannot tell you model numbers are they are both away from my location, from what I can gather that doesn't affect them too much though.
Both running latest 6.xx firmware, again not sure of numbers but the latest one that was out about a week ago. Sory for being so vague as both units are away from my location.
- JennCNov 01, 2016NETGEAR Employee Retired
You may need to have someone to be able to get to the admin page of the two NAS units. This is to check if the source and destination are reachable through the Internet, their firmware version.
Please also see this article: ReadyNAS: Replicate Troubleshooting
- macmanleeleapNov 02, 2016Aspirant
Model in one location, this is the uniot that needs backing up extrnally is ReadyNas 314 and the remote one is Netgear RN202-100NES. Both have 6.6.0 and connection to the internet. Ive done the DNS thing before you suggest that. I can see both units using online replicate login so both units ARE connected to the internet properly. The log does show this though as the connection is there.
