TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp
appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open.
assuming its possible, would love to see this available for x86 devices to stream directly from nas
- I don't know, I had the same problems before too, but I don't know what fixed it, sorted started working on its own.
you could try uninstalling and then reinstalling 1.8, making sure the memory is set to 500 or 600ish
you can also check the subsonic.log file for any clues - dcuellarAspirantHey Super,
I'm having an issue with special characters not displaying properly on subsonic. Characters such as accents mainly. (like é)
I'm trying to figure this out on my own but I can't understand what to do. Here is a link to a discussion about how to resolve it on subsonic.org. http://www.activeobjects.no/subsonic/fo ... php?t=4063
The problem is if an artist has one of these characters they will not be included in the list of artists. If an album has one it will not be displayed either, and if a song has one the whole album will not play because of it.
Any help with this would be greatly appreciated. I will gladly donate for your time in helping solve this. - dcuellarAspirantSubsonic was off again this morning also. I've tried everything. I'm up to 700 on memory now. Really frustrated with everything.
- 800 is about where mine stops crashing, but I would not expect that much needed for 12k files.
have you checked the subsonic.log file for any clues as what may be causing crashing?
have you removed subsonic from frontview, rebooted, re-installed?
what version of frontview/raidiator are you running? - dcuellarAspirantFirmware: RAIDiator 4.2.15
I'll try removing subsonic and rebooting, but just so Super knows, it's happening with Airvideo as well. - dcuellarAspirantI did all of the above. I'll let you know how it goes tomorrow morning and so on. Hopefully I can get the issue with the special characters resolved. Do you have this issue Techno?
If I am going to increase it to 800 I think it would be best for me to add memory. Anyone know of compatible memory for the Ultra6+? - bummer, if its not specific to subsonic, then I wouldn't bother with adjusting the memory more than 800 which worked fine for me on 1gig. It may be something bigger going wrong with raidiator.
yes I have the issue with special characters, http://www.activeobjects.no/subsonic/fo ... highlight=
I would guess that it goes in the subsonic.sh, but better if s-p takes a look at the solution in your thread. - dcuellarAspirantOk.
What about videos? Are you able to add videos? I don't see the option in this subsonic, but I know it is an option in subsonic, right? I'm only seeing "Add Music Folders" - dcuellarAspirantnevermind. I figured out the videos.
- dcuellarAspirantIs the Java included the latest java version?
