TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp
appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open.
assuming its possible, would love to see this available for x86 devices to stream directly from nas
- dcuellarAspirantTwo questions. One, why can we not post on the thread where you posted Subsonic?
Second question, I'm getting an error everytime I play a file that requires the lame transcoder. Is that transcoder the one provided by subsonic or is it one you put in there? If you did put it in there is there any way we can get a working one? - super_poussinVirtuoso
dcuellar wrote: Two questions. One, why can we not post on the thread where you posted Subsonic?
1) if I remember well,it' lame from debian repository , Airvideo did not provide one
2) it's forum's design
3) can you provide me a link if a file which cause problem with lame
4) which nas model and firmware version are you using ?
Super-Poussin
If you like my add-ons please donate :) - dcuellarAspirantI'm using Ultra 6 Plus. How do you want me to provide a link to a file? upload the song to like megaupload?
- super_poussinVirtuosocan you try :
Airvideo 1.2 all-in-one
(the all in one is the one I use at home
not shure m4a are supported ==> I think Airvideo for Linux alpha 4 did not support audio only files :(
I have include lame (I think it's not used by AirVideo) and Also faac
Skywalker:/c/webroot/AirVideo# ffmpeg
FFmpeg version UNKNOWN, Copyright (c) 2000-2010 Fabrice Bellard, et al.
built on May 5 2010 09:37:32 with gcc 4.4.1
configuration: --enable-pthreads --disable-shared --enable-static --enable-gpl --enable-libx264 --enable-libmp3lame --enable-libfaad --disable-decoder=aac
libavutil 50. 8. 0 / 50. 8. 0
libavcodec 52.52. 0 / 52.52. 0
libavformat 52.50. 0 / 52.50. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Skywalker:/c/webroot/AirVideo# faac --help
Freeware Advanced Audio Coder
FAAC 1.28
Usage: faac [options] infiles ...
Options:
-q <quality> Set quantizer quality.
-b <bitrate> Set average bitrate to x kbps. (ABR, lower quality mode)
-c <freq> Set the bandwidth in Hz. (default=automatic)
-o X Set output file to X (only for one input file)
-r Use RAW AAC output file.
-P Raw PCM input mode (default 44100Hz 16bit stereo).
-R Raw PCM input rate.
-B Raw PCM input sample size (8, 16 (default), 24 or 32bits).
-C Raw PCM input channels.
-X Raw PCM swap input bytes
-I <C,LF> Input channel config, default is 3,4 (Center third, LF fourth)
MP4 specific options:
-w Wrap AAC data in MP4 container. (default for *.mp4 and *.m4a)
-s Optimize MP4 container layout after encoding
--artist X Set artist to X
--writer X Set writer to X
--title X Set title to X
--genre X Set genre to X
--album X Set album to X
--compilation Set compilation
--track X Set track to X (number/total)
--disc X Set disc to X (number/total)
--year X Set year to X
--cover-art X Read cover art from file X
--comment X Set comment to X
Documentation:
--license Show the FAAC license.
--help Show this abbreviated help.
--long-help Show complete help.
More tips can be found in the audiocoding.com Knowledge Base at
<http://www.audiocoding.com/wiki/>
Skywalker:/c/webroot/AirVideo# ./ffmpeg -i /media/Videos/Be/be.m4a /media/Videos/Be/be.avi
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/media/Videos/Be/be.m4a':
Metadata:
major_brand : M4A
minor_version : 0
compatible_brands: M4A mp42isom
title : Be
author : Common
composer : Lonnie Lynn, Kanye West, Ceasar Frazier
album : Be
track : 1
date : 2005
encoder : iTunes v7.4.3.1, QuickTime 7.2
Duration: 00:02:24.26, start: 0.000000, bitrate: 129 kb/s
Stream #0.0(und): Audio: libfaad, 44100 Hz, 2 channels, s16, 128 kb/s
File '/media/Videos/Be/be.avi' already exists. Overwrite ? [y/N] y
Output #0, avi, to '/media/Videos/Be/be.avi':
Stream #0.0(und): Audio: mp2, 44100 Hz, 2 channels, s16, 64 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
size= 1267kB time=144.25 bitrate= 72.0kbits/s
video:0kB audio:1127kB global headers:0kB muxing overhead 12.445309% - dcuellarAspirantI don't know what to do with this. Excuse me.
And the files that do not work ARE aac m4a files. So this will not work? - dcuellarAspirantMy subsonic is still crashing on me. I've raised memory to 600 already and still it is crashing. I only have 12,000 songs. It seems that every morning I wake up it's down.
- that should be more than plenty for 12k songs
did you disable the search index?
login as an admin, settings > search > automatically update index = never
if stops crashing, then its something related to search index (which is one of the reasons to increase memory, but 600 should be fine) - dcuellarAspirantI'm gonna give it a try again. I had it like that per our conversation earlier, but I just checked it again and it was set back to daily. Must have been when I updated in Frontview.
- dcuellarAspirantI just don't see how this could be affecting it. When I click on update search index now it does it just fine. Why is it a problem when it does it automatically?
