MichaelR64
Jan 11, 2011Aspirant
Restarting par/unrar process on SABNZBD
Hi, I am using SABNZBD on my NVX pro pioneer. The unit had to restart after power loss and now has 130Gb of rar and par files waiting for the SABNZBD to process. However that doesn't process it, ...
MichaelR64
Jan 13, 2011Aspirant
WhoCares? wrote: In what directory are the files from the interrupted process? In the incomplete dir? If so, the best you can do is manually unpack the stuff and move it to the completed dir. I don't think SABnzbd has a restart mechanism for interrupted tasks.
-Stefan
Offcourse i can move them to my pc for processing but that is defeating the question: the reason for restarting is that i don't want to move 45Gb of data across the lan but just rather persuade my nas to process it again.
Anyway thx for the support, appreciate it !
