MichaelR64
Jan 11, 2011Aspirant
Restarting par/unrar process on SABNZBD
Hi, I am using SABNZBD on my NVX pro pioneer. The unit had to restart after power loss and now has 130Gb of rar and par files waiting for the SABNZBD to process. However that doesn't process it, ...
MichaelR64
Jan 14, 2011Aspirant
WhoCares? wrote: Generally with par2 r <name of par2 file>
Optionally you can specify what files to repair. Quite obviously you should be in the directory where the files to be repaired reside before issuing the above command ;)
-Stefan
that easy huh... hmm shouldn't be to hard then
