craigat
Dec 04, 2018Aspirant
RN31600 LOST SHARES
PLEASE HELP
HOW DO I RESTORE LOST SHARES ON MY RN31600 ??
I TURNED ON VIRUS SCAN,... IT CRASHED MY RN31600.... RE STARTED IT (FULL POWER CYCLE) & THE SHARES ARE GONE!
NOW THE RN316...
Dec 04, 2018Guru - Experienced User
I suggest contacting support via my.netgear.com. Data recovery will probably be needed. https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
Another option would be to connect the disks to a PC (sata or via a USB dock) and see if ReclaiMe sees the missing files ( https://www.reclaime.com/ )
craigat
Dec 12, 2018Aspirant
Thanks Stephen for the advice... I'm a pro Software Dev (28 yrs experience) myself & sure wouldnt charge for the initial inspection. This has happened thru no fault of my own! Netgear software is the worst quality I've ever seen... Just read the release notes to see how little testing is done.
I cant justify those prices so I guess I've lost it all.. $200 [(US$ I assume) is over 2 weeks food for my household]... & thats per hr!
Cheers
Craig
- StephenBDec 13, 2018Guru - Experienced User
If you have linux skills, you could enable ssh and attempt more troubleshooting from the linux command line. Downloading the log zip file, and looking at the details in there might also give you some clues as to what happened.
ReclaiMe is a fixed price recovery product, so you could try that one. The download is free, so you'd have some idea about what it could recover before purchasing it. Actual recovery would require purchase.
